BioShock Infinite
Publisher: 2K
From our
Bioshock Infinite review :
"Your character Booker’s trip to Columbia is in the interest of retrieving a girl, Elizabeth, from captivity. It’s imperative that you find her so that you can clear a pile of debts, but it’s increasingly clear as your time in columbia continues that this isn’t a simple hero's tale. Elizabeth has the power to control “tears in reality" that are popping up all over the city."
"It’s an adult, thoughtful and compelling work that shames many (if not most) other attempts in the medium. Bioshock Infinite is an incredibly good video game. It might be one of the best.
We use the handy in-built benchmarking tool to run a timedemo from two sections near the start of the game. However, we've found the game-generated results to be unreliable, so use FRAPS to record the frame rate over a 40 second sequence of gameplay during the second test. The results taken are an average of three repeated tests.
Nvidia GeForce GTX Titan Black 6GB
Nvidia GeForce GTX 780 Ti 3GB
Nvidia GeForce GTX 780 3GB
AMD Radeon R9 290X 4GB
ASUS Radeon R9 290 DirectCU II OC 4GB
AMD Radeon R9 290 4GB
Nvidia GeForce GTX 770 2GB
AMD Radeon R9 280X 3GB
Nvidia GeForce GTX 760 2GB
AMD Radeon R9 270X 2GB
Nvidia GeForce GTX 660 2GB
AMD Radeon R9 270 2GB
Nvidia GeForce GTX 750 Ti 2GB
AMD Radeon R9 260X 2GB
Frames Per Second
AMD Radeon R7 260X 2GB
20
30
40
50
60
70
80
90
Frames Per Second
Frames Per Second
Frames Per Second
Posted by Kodongo - Mon Mar 03 2014 10:02
Posted by Hustler - Mon Mar 03 2014 12:00
I thought I saw somewhere that the heat pipes on these CU models make them too high...although the ones on this don't seem to protrude as much as some others I've seen , maybe they've had a design revision???
Posted by tozsam - Mon Mar 03 2014 13:53
Posted by Skiddywinks - Mon Mar 03 2014 14:22
